Ok that's great any lead on p0235? Will check for splits as well is it just the air pipes to check? And will look at the three pin plug
Ok I have opcom how can I test with it?
Look for actuators test option
P0235 that will be 3 pin plug
Try repluging it or cleaning it but do not spray wd40
For now just air hoses to check
Best to check everything before spending money
If the plugs seems fine is there a sensor that will through up 0235?
You will see something like arm near turbo where 3 pin plug is that's called vane in dtc make sure it moves
But check first that plug, throttle valve, egr and air hoses
Does cylinder misfire dtc comes back after driving?
Only when below that 45 range
Strange
Its all time same cylinders or random numbers
Like now its 1 2 5 next time some others
Not a best thing if you will have junk in tank
Only ever seen 5 once it's usually 1 and 2. Of I read the codes with eml on 1 misfire is present and 2 is not. I have set Re creating the issue on the drove and I don't get any issue with the range is above 45
Ok sounds better
45 miles should be about 1.5 gallon in tank if tank is about 60l than its around 7l in tank
Can be air cached or all rubbish from bottom of tank
Here is some photos how it looks like an idea what's involved if you decide to check in tank
https://www.drive2.ru/l/773646/
