Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 25
  1. #11
    Member marky's Avatar
    May 2013
    North West
    6
    Vectra C 1.9CDTi (120) SRi
    OK I have bought a new stalk from VX and I still have the same problem with the cruise control.
    Next is to try a new clutch spring/switch.
    • #12
      Member sinbrad's Avatar
      Jun 2015
      Arbroath, Scotland
      5
      Vectra C 2.8 VXR
      Any Joy with this one? I'm having the same problem and Vx say that it's a New CIM that's needed. There are loads of similar stories on the net and I am amazed that if it is the CIM that has failed then how can there be so many. I've fitted new stalk, new clutch and brake switch and still the CC is playing up. I can understand if it was not functioning all the time but as it's intermittent can it be the CIM?
    • #13
      Member LarsDK's Avatar
      Jul 2015
      Denmark, Aabybro
      5
      Vectra C 1.8 GTS
      Quote Originally Posted by sinbrad View Post
      Hi
      Any luck since I have the same problem? What solved the problem?
      I have a Vectra C GTS Z18XE from May 2003
      BR,
      Lars
    • #14
      Jun 2015
      Arbroath, Scotland
      5
      Vectra C 2.8 VXR
      Unfortunately no luck as yet. Sometimes it works, sometimes it doesn't. My next port of call is to fit new switches which involves removing the steering wheel etc to get access to the CIM. I've read that it could be the actual switch but I won't know until I attempt it and when that'll be I can't say as I don't have much spare time at the moment. If and when I do get round to it I will post up the results?
    • #15
      Jul 2015
      Denmark, Aabybro
      5
      Vectra C 1.8 GTS
      I have just found a repair on a site from the Netherlands. I have just made the modification to my stalk and I will test it the next days to evaluate the result. I have taken a few pics of it so I can share with you in case it works.
      BR
      Lars
    • #16
      Jul 2015
      Denmark, Aabybro
      5
      Vectra C 1.8 GTS
      Quote Originally Posted by LarsDK View Post
      BR
      Lars
      CouldnĀ“t wait to post. I have just made the first test run and quite an improvement! It Works great now. It just tricked me once but that was not the car...just me forgetting to get my foot away from the clutch pedal :-)
      I have Pictures but here you can find the post from Netherland. I just dismantled the stalk, cleaned inside contacts with contactspray(remember to dry before installation!), lubricated the joints of the buttons(not the Electric), solder a tin point at each track where the CIM make electrical contact to the stalk..easy to see actually. Here it is with pics which make the language easier to understand :-)
      http://opel-forum.nl/viewtopic.php?f=129&t=169829
      BR
      Lars
    • #17
      Jun 2015
      Arbroath, Scotland
      5
      Vectra C 2.8 VXR
      I did carry out the dismantling of the stalk and cleaning but it was still intermittent. I did also bend the pins in the stalk holder so that they make better force when contacting the stalk but still the same. I may try the solder but would have thought that bending the pins would have had the same effect? I will keep an eye on your updates to see if this is a permanent fix or just temporary? Thanks
    • #18
      Jun 2015
      Arbroath, Scotland
      5
      Vectra C 2.8 VXR
      Hi Lars,
      Any update on this, has the CC remained good?
    • #19
      Jun 2015
      Arbroath, Scotland
      5
      Vectra C 2.8 VXR
      Ok guys, just a quick one. I've seen on youtube somewhere a test for the cruise control stalk. I've searched opcom and cannot find it under any section. I just want to be able to test that the switches are working ie tell tale but cannot find it for cruise control stalk?
    • #20
      Jul 2015
      Denmark, Aabybro
      5
      Vectra C 1.8 GTS
      Hi
      Only worked for a few days. I think its a bad connection since the stalk are moved up and down thousand times and this wear out the connection between stalk and cim for the CC. It should have been a plug instead!
      For opcom, just go to engine module. I think it was there I found the test mode. Strangely, my buttons seems to work when in testmode which kind of rules out the bad connection issue. Could it be a faulty engine module? The ECM? It has a reputation of breaking because its mounted directly to the engine and heat and vibrations breaks the inside ground wires. I haven't had the time to take the ECM apart and maybe the electronics are sealed in a gel.
      BR
      Lars
  1. Cruise Control
    By Gav in forum Astra
    Last Post: 17th November 2014, 09:51 PM
vectra c cruise control not working
b3794 vectra
vectra cruise control cutting out
vauxhall vectra cruise control switches off
vectra cruise control not working
vectra c cruise control fuse
vauxhall vectra c cruise control not working
vauxhall vectra cruise control problems
vectra c cruise control fault
vectra c cruise control keeps turning off
vauxhall vectra cruise control not working
vauxhall cruise control problems
vectra cruise control fuse
b3794-08
would a faulty cim affect power steeringOpel B3794vauxhall astra cruise control not workingb3794 fault codevauxhall vectra c cruise controlvauxhall cruise control cutting outcruise control vectra flickers on and offvauxhall fault code b3794vauxhall insignia cruise control faultcruise control not working vectra c
