Me again. As it may be a problem of supply perhaps I should point out another possible discrepancy over the fitting instructions. With the supplied new loom was a single cable terminating in a fuse holder into which I had to insert two 5 amp fuses. The holder itself is fitted with a fuse blade and I had to insert it into Fuse Position 15 (FR15) in the REC. The point is there are no blade contacts in this fuse FR15 position - it is empty, not even as a 'spare' fuse position that could be brought into use. So, in terms of the fitting instructions what is the point of putting a fuse blade into a position that has no contacts and therefore no supply? Is it just a convenient 'parking' position for the holder with the two fuses or am I missing something!
