IL |
Part No. |
KAT No. |
Description |
Range |
Range |
QTY |
BRAKE PIPES AND HOSES (CONTD.) |
1 |
13116134 |
55 62 250 |
HOSE, PIPE AND BRACKET ASSY., REAR BRAKE, RH (USED WITH DRUM BRAKES) |
HATCH, SALOON L08, L48, L69 |
(C)
(C)
(C)
(C)
(C) |
-92
-95
-98
-9B
-9G |
1 |
1 |
13334948 |
5 62 179 |
(C) 92-
(C) 95-
(C) 98-
(C) 9B-
(C) 9G- |
1 |
1 |
13116133 |
55 62 249 |
HOSE, PIPE AND BRACKET ASSY., REAR BRAKE, LH (USED WITH DRUM BRAKES) |
(C)
(C)
(C)
(C)
(C) |
-92
-95
-98
-9B
-9G |
1 |
1 |
13334947 |
5 62 178 |
(C) 92-
(C) 95-
(C) 98-
(C) 9B-
(C) 9G- |
1 |
2 |
13116137 |
55 62 248 |
HOSE, PIPE AND BRACKET ASSY., REAR BRAKE, RH (USED WITH DISC BRAKES) |
1 |
4 |
13112908 |
5 43 106 |
-SCREW, HOLLOW, M10, HOSE TO CALIPER, REAR |
2 |
5 |
24444010 |
5 62 732 |
-SEAL, RING, 10 X 15, HOSE TO CALIPER, REAR |
4 |
3 |
13116136 |
55 62 247 |
HOSE, PIPE AND BRACKET ASSY., REAR BRAKE, LH (USED WITH DISC BRAKES) |
1 |
4 |
13112908 |
5 43 106 |
2 |
5 |
24444010 |
5 62 732 |
4 |
6 |
9186069 |
5 64 988 |
CLAMP, 2-WAY, BRAKE PIPE FIXING, REAR |
AR |
7 |
24443614 |
5 64 990 |
-SCREW, 40 X 18MM, CLAMP |
AR |
8 |
90498320 |
5 64 429 |
PLATE, LOCKING, REAR BRAKE HOSE TO BRACKET |
2 |
9 |
11093961 |
20 05 104 |
SCREW, M6 X 16, BRACKET, REAR BRAKE HOSE |
2 |
10 |
90095094 |
5 64 656 |
CLAMP, 2-WAY, BRAKE PIPE, REAR |
ESTATE, VAN L35, L70 |
2 |
