recalibrate steering angle clear dtcs and should be ok you can try with opcom but not sure about results but you can try as if it will work you will save ££ if not go to someone with tech2
I will try this m8 thanks for your help will keep you posted with results
update had my tracking done was out drove car for a bit haho light out happy days cheap fix
