comfort close is not an option you can turn off I think.. I know opcom can fry door modules (if using the same type of system) which results in loss of comfort close..
I would wait for someone who knows tigras a little better than myself
Hi there! i was fooling around with opcom on my tigra twintop 2006 and i accidentally broke the comfort closure now i cant close the windows via remote nor via the key cylinder. i think i did something stupid under the code index tab. can anyone help please?
but if i had a problem with door module lock unlock and deadlock could still work? i dont have a problem with these functions! the only thing is i cant close windows... thats why i'm pretty sure i did something stupid with opcom and codec index.
So sounds like the windows have lost their one touch operation learnt stops. This would normally cause comfort closing to lose functionality. Does one touch still function or not? You could have a look in the programming menu of the electrohydraulic hardtop and try reprogramming drivers & passenger windows.
no one touch still works perfectly! i also had both windows reprogrammed by opel with tech2! but nothing changed. the guy in opel told me that he had to see it further some other time but he didn't knew what could be wrong. i told him about opcom but he didnt knew what to answer. could be a problem of bcm? i mean could be get damaged when i remove it? but it doesn't make sence because all the other functions of the car work like a charm!
