Hi, welcome... I will try to get you the pinout later today after some dinner
hello , to everyone on the website im a new member here in your website hope to be a good one . im lately bought an astra h GID display + and a ccrt 700 philips radio i wanted to install this system on an astra g 2001 saloon i modified its display connector to be ( 32 pin connector - gray ) . ( the problem that i wanted the pinout of the - astra h GID - to compare it with my wires connection on the astra g / no.2 i tried to test the screen on the gray connector without any radio just the plug it has a blue input by the way it never starts or illuminate and this is a problem too. i suspect it to be that it needs me to connect the ccrt700 which i didnt connect it yet as i recently bought it and looking for the 26 pin to 36 pin wiring plug , so im sorry once again but i needed to clarify from you ( if you could supply me the pinout of the astra h GID / what you think about the display that never starts ) hope to benefit from the members experience in this forum and thanks for all ,wish to receive your replies soon.
Hello soulman , and thanks for your reply.I will wait thank you.
I forgot, apologies, will do in a bit
thank you , never mind , i will wait
Pin 3 & 5 - Positive Live
Pin 1 & 2 - Ground
Pin 17 - Midspeed CAN Green
Pin 18 - Midspeed CAN White
Pin 22 - Midspeed Can Green
Pin 23 - Midspeed Can White
Pin 19 - Midspeed Can White
Pin 20 - Midspeed Can Green
Pin 25 - Low Speed Can Green
Pin 28 - Low Speed Can Green
Pin 24 - Ground data
Pin 9 - Nav data low (yellow)
Pin 8 - Nav data high (blue)
hello soulman and thanks for your help i really appreciate it but could you clarify me the terms (Pin 17 - Midspeed CAN Green
i didnt understand what it used for in the car its not like this in the attachment its completley different its in ( can low high mid ) i dint understand that so could you if -you may- put it in phrases like this in the attachment the wire and its function in the car ( washer \ light \ brake \ engine \ ecu ) something i can understand instead of ( can low high mid ) . i really appreciate your respond and sorry for bothering you.
