Results 1 to 7 of 7
Hybrid View
    Member ahmed elalfy's Avatar
    Feb 2020
    cairo, egypt
    5
    astra g
    astra h GID display, need some assistance.
    hello , to everyone on the website im a new member here in your website hope to be a good one . im lately bought an astra h GID display + and a ccrt 700 philips radio i wanted to install this system on an astra g 2001 saloon i modified its display connector to be ( 32 pin connector - gray ) . ( the problem that i wanted the pinout of the - astra h GID - to compare it with my wires connection on the astra g / no.2 i tried to test the screen on the gray connector without any radio just the plug it has a blue input by the way it never starts or illuminate and this is a problem too. i suspect it to be that it needs me to connect the ccrt700 which i didnt connect it yet as i recently bought it and looking for the 26 pin to 36 pin wiring plug , so im sorry once again but i needed to clarify from you ( if you could supply me the pinout of the astra h GID / what you think about the display that never starts ) hope to benefit from the members experience in this forum and thanks for all ,wish to receive your replies soon.
  2. #2
    Hi, welcome... I will try to get you the pinout later today after some dinner
  3. #3
    Feb 2020
    cairo, egypt
    5
    astra g
    Hello soulman , and thanks for your reply.I will wait thank you.
  4. #4
    Pin 3 & 5 - Positive Live
    Pin 1 & 2 - Ground
    Pin 17 - Midspeed CAN Green
    Pin 18 - Midspeed CAN White
    Pin 22 - Midspeed Can Green
    Pin 23 - Midspeed Can White
    Pin 19 - Midspeed Can White
    Pin 20 - Midspeed Can Green
    Pin 25 - Low Speed Can Green
    Pin 28 - Low Speed Can Green
    Pin 24 - Ground data
    Pin 9 - Nav data low (yellow)
    Pin 8 - Nav data high (blue)
  5. #5
    Feb 2020
    cairo, egypt
    5
    astra g
    hello soulman and thanks for your help i really appreciate it but could you clarify me the terms (Pin 17 - Midspeed CAN Green
    Pin 9 - Nav data low (yellow)Click image for larger version.
    i didnt understand what it used for in the car its not like this in the attachment its completley different its in ( can low high mid ) i dint understand that so could you if -you may- put it in phrases like this in the attachment the wire and its function in the car ( washer \ light \ brake \ engine \ ecu ) something i can understand instead of ( can low high mid ) . i really appreciate your respond and sorry for bothering you.
  6. #6
    I forgot, apologies, will do in a bit
  7. #7
    Feb 2020
    cairo, egypt
    5
    astra g
    thank you , never mind , i will wait
  1. ASTRA H DISPLAY EEPROM GID 93C66 Siemens VDO Ident SE
    By nicos in forum Infotainment - ICE - In Car Entertainment
    Last Post: 4th January 2021, 05:46 PM
  2. Astra AH GID Screen Fault
    By guy97 in forum Astra
    Last Post: 28th April 2019, 02:51 PM
  3. NEED CODE FOR ASTRA H DISPLAY GID Delphi Grundig Ident BG
    Last Post: 28th June 2018, 07:25 PM
astra h bid pinout
delphi grundig display gid pinout
