You are correct in the fact that you will need module mic and loom plus vci.
They are a nightmare now.
Hi all,
Having just bought a 2015 Astra J Elite, I am somewhat surprised that there appears to be no Bluetooth
I’m sure this has been asked a hundred times and I’ve seen many answers but very little info on the Navi 650.
I assume I’d need a uhp high module, microphone, custom loom and the vci code, and also someone capable of installing it.
Or by some fluke the Navi 650 just needs some config.
Any help and advice appreciated.
Cheers all Adey
If you were nearer I could have done it for you
Which bit is the nightmare, programming? I’m guessing I should be able to get the bits from ebay.
I did see somewhere that the vci code might not be necessary for the navi head units.
I'm positive you will need vci code.
Early 2010 2011 cars you can occasionally get away without vci
You need someone with access to online gm infotech and a mdi
