IL |
Part No. |
KAT No. |
Description |
Range |
Range |
QTY |
ABS HYDRAULIC UNIT |
1 |
(93174919) |
(55 30 124) |
UNIT, HYDRAULIC, ABS, WITH CONTROL UNIT (IDENT GN) (EXCEPT ELECTRONIC STABILITY PROGRAM) (NLS.- USE 93182330) |
(C)
(C) |
-45999999
-48999999 |
1 |
2 |
(93174920) |
(62 35 288) |
-CONTROL UNIT, WITH GASKET (EXCEPT ELECTRONIC STABILITY PROGRAM) (NLS.- USE 93182331) |
(C)
(C) |
-45999999
-48999999 |
1 |
1 |
(93182330) |
(55 30 130) |
UNIT, HYDRAULIC, ABS, WITH CONTROL UNIT (IDENT GW) (EXCEPT ELECTRONIC STABILITY PROGRAM) (NLS.- USE 93183032) |
(C) 52000001-
(C) 55000001-
(C) 58000001- |
52091535
55100078
58063072 |
1 |
2 |
(93182331) |
(62 35 394) |
-CONTROL UNIT, WITH GASKET (EXCEPT ELECTRONIC STABILITY PROGRAM) (NLS.- USE 93183033) |
(C) 52000001-
(C) 55000001-
(C) 58000001- |
52091535
55100078
58063072 |
1 |
1 |
(93183032) |
(55 30 137) |
UNIT, HYDRAULIC, ABS, WITH CONTROL UNIT (IDENT HA) (EXCEPT ELECTRONIC STABILITY PROGRAM) (NLS.- USE 93186371) |
(C) 52091536-
(C) 55100079-
(C) 58063073- |
52175676
55185940
58114084 |
1 |
2 |
(93183033) |
(62 35 405) |
-CONTROL UNIT, WITH GASKET (EXCEPT ELECTRONIC STABILITY PROGRAM) (NLS.- USE 93186187) |
(C) 52091536-
(C) 55100079-
(C) 58063073- |
52175676
55185940
58114084 |
1 |
1 |
93186371 |
55 30 150 |
UNIT, HYDRAULIC, ABS, WITH CONTROL UNIT (IDENT HA) (EXCEPT ELECTRONIC STABILITY PROGRAM) |
(C) 52175677-
(C) 55185941-
(C) 58114085- |
72094718
75086479
78048187 |
1 |
1 |
93191453 |
55 30 160 |
UNIT, HYDRAULIC, ABS, WITH CONTROL UNIT (EXCEPT ELECTRONIC STABILITY PROGRAM) (IDENT BK) |
(C) 72094719-
(C) 75086480-
(C) 78048188-
(C) 8B000001- |
1 |
2 |
93186187 |
62 35 473 |
-CONTROL UNIT, WITH GASKET (EXCEPT ELECTRONIC STABILITY PROGRAM) |
(C) 52175677-
(C) 55185941-
(C) 58114085- |
72094718
75086479
78048187 |
1 |
2 |
93191454 |
12 32 185 |
(C) 72094719-
(C) 75086480-
(C) 78048188-
(C) 8B000001- |
1 |
3 |
(93178594) |
(55 30 125) |
UNIT, HYDRAULIC, ABS, WITH CONTROL UNIT (IDENT GP) (FOR ELECTRONIC STABILITY PROGRAM) (EXCEPT HILL-START ASSISTANT) (EXCEPT DEFLATION DETECTION SYSTEM) (NLS.- USE 93182334 OR 93182448 AS REQUIRED) |
(C)
(C) |
-45999999
-48999999 |
1 |
4 |
(93178595) |
(62 35 289) |
-CONTROL UNIT, WITH GASKET (FOR ELECTRONIC STABILITY PROGRAM) (EXCEPT HILL-START ASSISTANT) (EXCEPT DEFLATION DETECTION SYSTEM) (NLS.- USE 93182335 OR 93182449 AS REQUIRED) |
(C)
(C) |
-45999999
-48999999 |
1 |
3 |
(93182334) |
(55 30 131) |
UNIT, HYDRAULIC, ABS, WITH CONTROL UNIT (IDENT GX) (FOR ELECTRONIC STABILITY PROGRAM) (EXCEPT HILL-START ASSISTANT) (EXCEPT DEFLATION DETECTION SYSTEM) (NLS.- USE 93182332) |
(C) 52000001-
(C) 55000001-
(C) 58000001- |
52091535
55100078
58063072 |
1 |
Note: USED WITH MANUAL TRANSMISSION |
4 |
(93182335) |
(62 35 395) |
-CONTROL UNIT, WITH GASKET (FOR ELECTRONIC STABILITY PROGRAM) (EXCEPT HILL-START ASSISTANT) (EXCEPT DEFLATION DETECTION SYSTEM) (NLS.- USE 93182333) |
(C) 52000001-
(C) 55000001-
(C) 58000001- |
52091535
55100078
58063072 |
1 |
3 |
(93182332) |
(55 30 135) |
UNIT, HYDRAULIC, ABS, WITH CONTROL UNIT (IDENT HB) (FOR ELECTRONIC STABILITY PROGRAM) (EXCEPT HILL-START ASSISTANT) (EXCEPT DEFLATION DETECTION SYSTEM) (NLS.- USE 93186184) |
(C) 52091536-
(C) 55100079-
(C) 58063073- |
52175676
55185940
58114084 |
1 |
4 |
(93182333) |
(62 35 404) |
-CONTROL UNIT, WITH GASKET (FOR ELECTRONIC STABILITY PROGRAM) (EXCEPT HILL-START ASSISTANT) (EXCEPT DEFLATION DETECTION SYSTEM) (NLS.- USE 93186188) |
(C) 52091536-
(C) 55100079-
(C) 58063073- |
52175676
55185940
58114084 |
1 |
3 |
(93186184) |
(55 30 148) |
UNIT, HYDRAULIC, ABS, WITH CONTROL UNIT (IDENT AL) (FOR ELECTRONIC STABILITY PROGRAM) (EXCEPT HILL-START ASSISTANT) (EXCEPT DEFLATION DETECTION SYSTEM) (NLS.- USE 93191515) |
EXCEPT OPC, VXR |
(C) 52175677-
(C) 55185941-
(C) 58114085- |
72094718
75086479
78048187 |
1 |
4 |
(93186188) |
(62 35 474) |
-CONTROL UNIT, WITH GASKET (FOR ELECTRONIC STABILITY PROGRAM) (EXCEPT HILL-START ASSISTANT) (EXCEPT DEFLATION DETECTION SYSTEM) (NLS.- USE 93191516) |
EXCEPT OPC, VXR |
(C) 52175677-
(C) 55185941-
(C) 58114085- |
72094718
75086479
78048187 |
1 |
3 |
93191515 |
55 30 161 |
UNIT, HYDRAULIC, ABS, WITH CONTROL UNIT (IDENT BN) (FOR ELECTRONIC STABILITY PROGRAM) (EXCEPT HILL-START ASSISTANT) |
EXCEPT OPC, VXR |
(C) 72094719-
(C) 75086480-
(C) 78048188-
(C) 8B000001- |
1 |
4 |
93191516 |
12 32 186 |
-CONTROL UNIT, WITH GASKET (FOR ELECTRONIC STABILITY PROGRAM) (EXCEPT HILL-START ASSISTANT) (EXCEPT DEFLATION DETECTION SYSTEM) |
EXCEPT OPC, VXR |
(C) 72094719-
(C) 75086480-
(C) 78048188-
(C) 8B000001- |
1 |
3 |
(93180955) |
(55 30 128) |
UNIT, HYDRAULIC, ABS, WITH CONTROL UNIT (IDENT GT) (FOR ELECTRONIC STABILITY PROGRAM) (EXCEPT HILL-START ASSISTANT) (FOR DEFLATION DETECTION SYSTEM) (NLS.- USE 93182326 OR 93182448 AS REQUIRED) |
(C)
(C) |
-45999999
-48999999 |
1 |
4 |
(93180956) |
(62 35 377) |
-CONTROL UNIT, WITH GASKET (FOR ELECTRONIC STABILITY PROGRAM) (EXCEPT HILL-START ASSISTANT) (FOR DEFLATION DETECTION SYSTEM) (NLS.- USE 93182327 OR 93182449 AS REQUIRED) |
(C)
(C) |
-45999999
-48999999 |
1 |
3 |
(93182326) |
(55 30 129) |
UNIT, HYDRAULIC, ABS, WITH CONTROL UNIT (IDENT GY) (FOR ELECTRONIC STABILITY PROGRAM) (EXCEPT HILL-START ASSISTANT) (FOR DEFLATION DETECTION SYSTEM) (NLS.- USE 93182328) |
(C) 52000001-
(C) 55000001-
(C) 58000001- |
52091535
55100078
58063072 |
1 |
4 |
(93182327) |
(62 35 393) |
-CONTROL UNIT, WITH GASKET (FOR ELECTRONIC STABILITY PROGRAM) (EXCEPT HILL-START ASSISTANT) (FOR DEFLATION DETECTION SYSTEM) (NLS.- USE 93182329) |
(C) 52000001-
(C) 55000001-
(C) 58000001- |
52091535
55100078
58063072 |
1 |
3 |
(93182328) |
(55 30 134) |
UNIT, HYDRAULIC, ABS, WITH CONTROL UNIT (IDENT HC) (FOR ELECTRONIC STABILITY PROGRAM) (EXCEPT HILL-START ASSISTANT) (FOR DEFLATION DETECTION SYSTEM) (NLS.- USE 93186185) |
(C) 52091536-
(C) 55100079-
(C) 58063073- |
52175676
55185940
58114084 |
1 |
4 |
93182329 |
62 35 403 |
-CONTROL UNIT, WITH GASKET (FOR ELECTRONIC STABILITY PROGRAM) (EXCEPT HILL-START ASSISTANT) (FOR DEFLATION DETECTION SYSTEM) |
(C) 52091536-
(C) 55100079-
(C) 58063073- |
52175676
55185940
58114084 |
1 |
3 |
(93186185) |
(55 30 149) |
UNIT, HYDRAULIC, ABS, WITH CONTROL UNIT (IDENT AM) (FOR ELECTRONIC STABILITY PROGRAM) (EXCEPT HILL-START ASSISTANT) (FOR DEFLATION DETECTION SYSTEM) (NLS.- USE 93191515) |
EXCEPT OPC, VXR |
(C) 52175677-
(C) 55185941-
(C) 58114085- |
72094718
75086479
78048187 |
1 |
4 |
(93186189) |
(62 35 475) |
-CONTROL UNIT, WITH GASKET (FOR ELECTRONIC STABILITY PROGRAM) (EXCEPT HILL-START ASSISTANT) (FOR DEFLATION DETECTION SYSTEM) (NLS.- USE 93191516) |
EXCEPT OPC, VXR |
(C) 52175677-
(C) 55185941-
(C) 58114085- |
72094718
72086479
78048187 |
1 |
3 |
93191515 |
55 30 161 |
EXCEPT OPC, VXR |
(C) 72094719-
(C) 75086480-
(C) 78048188-
(C) 8B000001- |
1 |
4 |
93191516 |
12 32 186 |
EXCEPT OPC, VXR |
(C) 72094719-
(C) 75086480-
(C) 78048188-
(C) 8B000001- |
1 |
3 |
(93182448) |
(55 30 132) |
UNIT, HYDRAULIC, ABS, WITH CONTROL UNIT (IDENT HJ) (FOR ELECTRONIC STABILITY PROGRAM) (EXCEPT HILL-START ASSISTANT) (NLS.- USE 93183038) |
(C) 52000001-
(C) 55000001-
(C) 58000001- |
52091535
55100078
58063072 |
1 |
Note: USED WITH AUTOMATIC TRANSMISSION |
4 |
(93182449) |
(62 35 396) |
-CONTROL UNIT, WITH GASKET (FOR ELECTRONIC STABILITY PROGRAM) (EXCEPT HILL-START ASSISTANT) (NLS.- USE 93183039) |
(C) 52000001-
(C) 55000001-
(C) 58000001- |
52091535
55100078
58063072 |
1 |
3 |
(93183038) |
(55 30 138) |
UNIT, HYDRAULIC, ABS, WITH CONTROL UNIT (IDENT HK) (FOR ELECTRONIC STABILITY PROGRAM) (EXCEPT HILL-START ASSISTANT) (NLS.- USE 93186182) |
(C) 52091536-
(C) 55100079-
(C) 58063073- |
52175676
55185940
58114084 |
1 |
4 |
93183039 |
62 35 406 |
-CONTROL UNIT, WITH GASKET (FOR ELECTRONIC STABILITY PROGRAM) (EXCEPT HILL-START ASSISTANT) |
(C) 52091536-
(C) 55100079-
(C) 58063073- |
52175676
55185940
58114084 |
1 |
3 |
(93186182) |
(55 30 146) |
UNIT, HYDRAULIC, ABS, WITH CONTROL UNIT (IDENT AJ) (FOR ELECTRONIC STABILITY PROGRAM) (EXCEPT HILL-START ASSISTANT) (NLS.- USE 93191515) |
(C) 52175677-
(C) 55185941-
(C) 58114085- |
72094718
75086479
78048187 |
1 |
4 |
(93186190) |
(62 35 476) |
-CONTROL UNIT, WITH GASKET (FOR ELECTRONIC STABILITY PROGRAM) (EXCEPT HILL-START ASSISTANT) (NLS.- USE 93191516) |
(C) 52175677-
(C) 55185941-
(C) 58114085- |
72094718
75086479
78048187 |
1 |
3 |
93191515 |
55 30 161 |
(C) 72094719-
(C) 75086480-
(C) 78048188-
(C) 8B000001- |
1 |
4 |
93191516 |
12 32 186 |
(C) 72094719-
(C) 75086480-
(C) 78048188-
(C) 8B000001- |
1 |
3 |
(93178596) |
(55 30 126) |
UNIT, HYDRAULIC, ABS, WITH CONTROL UNIT (IDENT GQ) (FOR ELECTRONIC STABILITY PROGRAM) (FOR HILL-START ASSISTANT) (NLS.- USE 93182450) |
(C)
(C) |
-45999999
-48999999 |
1 |
3 |
(93182450) |
(55 30 133) |
UNIT, HYDRAULIC, ABS, WITH CONTROL UNIT (IDENT GZ) (FOR ELECTRONIC STABILITY PROGRAM) (FOR HILL-START ASSISTANT) (NLS.- USE 93183027) |
(C) 52000001-
(C) 55000001-
(C) 58000001- |
52091535
55100078
58063072 |
1 |
3 |
(93183027) |
(55 30 136) |
UNIT, HYDRAULIC, ABS, WITH CONTROL UNIT (IDENT HD) (FOR ELECTRONIC STABILITY PROGRAM) (FOR HILL-START ASSISTANT) (NLS.- USE 93186183) |
(C) 52091536-
(C) 55100079-
(C) 58063073- |
52175676
55185940
58114084 |
1 |
3 |
(93186183) |
(55 30 147) |
UNIT, HYDRAULIC, ABS, WITH CONTROL UNIT (IDENT AK) (FOR ELECTRONIC STABILITY PROGRAM) (FOR HILL-START ASSISTANT) (NLS.- USE 93190007) |
(C) 52175677-
(C) 55185941-
(C) 58114085- |
52999999
55999999
58999999 |
1 |
3 |
(93190007) |
(5 30 157) |
UNIT, HYDRAULIC, ABS, WITH CONTROL UNIT (FOR ELECTRONIC STABILITY PROGRAM) (FOR HILL-START ASSISTANT) (IDENT BP) (NLS.- USE 93191519) |
(C) 62000001-
(C) 65000001-
(C) 68000001-
(C) 8B000001- |
1 |
3 |
(93186182) |
(55 30 146) |
OPC, VXR |
1 |
4 |
(93186190) |
(62 35 476) |
OPC, VXR |
1 |
5 |
13106978 |
55 30 781 |
SCREW, M8 X 45, ABS HYDRAULIC CONTROL UNIT TO BRACKET (EXCEPT ELECTRONIC STABILITY PROGRAM) |
(C)
(C)
(C) |
-62
-65
-68 |
3 |
6 |
11900174 |
20 00 628 |
SCREW, M8 X 30, ABS HYDRAULIC CONTROL UNIT TO BRACKET |
AR |
7 |
13106979 |
55 30 782 |
BUMPER, HYDRAULIC UNIT TO BRACKET (EXCEPT ELECTRONIC STABILITY PROGRAM) |
3 |
8 |
13157581 |
55 30 783 |
SLEEVE, HYDRAULIC UNIT TO BRACKET, 23 X 8 X 20MM (EXCEPT ELECTRONIC STABILITY PROGRAM) |
3 |
9 |
(13106973) |
(55 30 518) |
BRACKET, ASSY., HYDRAULIC UNIT, COMPLETE (EXCEPT ELECTRONIC STABILITY PROGRAM) (NLS.- USE 13190872) |
(C)
(C)
(C) |
-42999999
-55004775
-58005794 |
1 |
11 |
13106974 |
55 30 519 |
BRACKET, ASSY., HYDRAULIC UNIT, COMPLETE (FOR ELECTRONIC STABILITY PROGRAM) |
(C)
(C)
(C) |
-42999999
-55004775
-58005794 |
1 |
10 |
13214939 |
55 30 528 |
BRACKET, ASSY., HYDRAULIC UNIT, COMPLETE (EXCEPT ELECTRONIC STABILITY PROGRAM) |
(C) 52000001-
(C) 55004775-
(C) 58005795-
(C) 8B000001- |
1 |
11 |
(13190873) |
(55 30 524) |
BRACKET, ASSY., HYDRAULIC UNIT, COMPLETE (FOR ELECTRONIC STABILITY PROGRAM) (NLS.- USE 13214940) |
(C) 52000001-
(C) 55004775-
(C) 58005795- |
52999999
55999999
58999999 |
1 |
12 |
13214940 |
55 30 529 |
(C) 62000001-
(C) 65000001-
(C) 68000001-
(C) 8B000001- |
1 |
13 |
11101291 |
20 05 018 |
SCREW, M6 X 10, ABS HYDRAULIC CONTROL UNIT TO BRACKET (EXCEPT ELECTRONIC STABILITY PROGRAM) |
(C)
(C)
(C) |
-62
-65
-68 |
3 |
14 |
11096091 |
20 05 054 |
SCREW, M6 X 14, ABS HYDRAULIC CONTROL UNIT TO BRACKET (FOR ELECTRONIC STABILITY PROGRAM) |
(C)
(C)
(C) |
-62
-65
-68 |
3 |
14 |
11096091 |
20 05 054 |
SCREW, M6 X 14, ABS HYDRAULIC CONTROL UNIT TO BRACKET |
(C) 62-
(C) 65-
(C) 68- |
3 |
15 |
13106977 |
55 30 520 |
BRACE, HYDRAULIC UNIT BRACKET |
(C)
(C)
(C) |
-52999999
-55999999
-58999999 |
1 |
15 |
13106977 |
55 30 520 |
BRACE, HYDRAULIC UNIT BRACKET (EXCEPT ELECTRONIC STABILITY PROGRAM) |
(C) 62000001-
(C) 65000001-
(C) 68000001- |
62
65
68 |
1 |
16 |
13214941 |
55 30 530 |
BRACE, HYDRAULIC UNIT BRACKET (FOR ELECTRONIC STABILITY PROGRAM) |
(C) 62000001-
(C) 65000001-
(C) 68000001- |
62
65
68 |
1 |
16 |
13214941 |
55 30 530 |
(C) 62-
(C) 65-
(C) 68- |
1 |
17 |
11092154 |
20 02 134 |
SCREW, HEX.HD., M8 X 25, SUPPORT FIXING |
AR |
18 |
24430143 |
8 17 965 |
NUT, INSERT, M8, SUPPORT FIXING |
1 |
19 |
90575881 |
5 65 890 |
NUT, CAGED, M8, HYDRAULIC UNIT BRACKET TO SUPPORT |
2 |
20 |
13107111 |
55 30 521 |
SUPPORT, BRACKET, HYDRAULIC UNIT |
1 |
21 |
11092154 |
20 02 134 |
SCREW, HEX.HD., M8 X 25, BRACE TO FRAME |
1 |
22 |
90540018 |
15 10 180 |
FIXING AGENT, 100GRAMS, BRAKE MODULATOR |
AR |
