Page 1 of 4 1 2 3 4 LastLast
Results 1 to 10 of 32
    Member VXDspud's Avatar
    Jan 2017
    Wiltshire
    21
    Vectra C 1.9CDTI Wagon
    Vectra c faclift brake conversion
    Hi all new here i have a vectra wagon 1.9 CDTI im getting a fmic sorted this weekend and thought i would bolt on some bigger brakes,
    What it is ive bought some preface lift 3.2 v6 2005 front and back hubs with everything fitted (calipers disks ect ect)
    Will it be a case of unbolting everything old on my car and putting the 3.2's on easyly enough?
    Other than that my wagon has stage 2 remap with egr delete and dpf drilled and deleted with injector boost box soon to have front mount fitted, getting it ready for PVS 2017 so you may see it up there
    Anyway cheers all in advance happy new vaux year, kris
      Jan 2017
      Wiltshire
      21
      Sent from my SM-G935F using Tapatalk
      I think 3.2's had different shaft ends more splines, check that first, not sure if abs/speed sensors has any difference soulman is bit more in c's he should know. But if you are getting out more than 100bhp on top of oem 3.2's brake discs wont be best you will need anyway perfomorance aftermarket ones to stop it properly, but once again is down to your driving style
      Sent from my HTC One M9 using Tapatalk
      VIP+ Gav's Avatar
      Nov 2013
      Bristol
      285
      Zafira Tourer & Corsa D
      If you just swap the disc, calipers and cradle then it should be fine.
      Make sure you have big enough wheels too
      Gav
      14 Zafira Tourer Techline FULLY LOADED
      VAUXCOM UPA USB AUTODATA TOLERANCE AVAILABLE IN BRISTOL AND SOUTHWEST
      the 3.2 drive shafts are compatible with the 1.9's so if you really needed to you can fit the hubs and everything but you dont really know the history of them so would advise against that.
      Yea they are same hubs are same too
      Jan 2017
      Wiltshire
      21
      Thanks for all the replys lads easyier for the lads to get them off at scrappy the 3.2 looked VERY clean didnt see why it was in there to be honnest and new into yard,
      Im running 18's
      Cheers again kris
      I can bet failed engine or floods
      I like to say if you go to scrappy for parts take from crashed one that way you know it was driveable before
    • #9
      Quote Originally Posted by domtorredo View Post
      I know, as I was running 3.2 shafts on my 1.9
    • #10
      Jan 2017
      Wiltshire
      21
      Fairpoint domtorredo all looks good going to give them a look over minro strip clean and paint,
      Nice one soulman got a good deal on all 4 so should be good
  1. Vectra c rear electric windows conversion
    By sarah1331 in forum Vectra
    Last Post: 27th June 2014, 06:27 PM
  2. DOT 4 vs DOT 5 / 5.1 Brake fluid
    By T888 RHM in forum Mechanical
    Last Post: 21st August 2013, 06:25 PM
  3. Replies: 3
    Last Post: 3rd July 2013, 12:05 AM
  4. Brake Pads
    By Adam_SRI in forum Mechanical
    Last Post: 18th March 2012, 11:12 AM
