Anyone please
I have a vauxhall combo van 1.3 cdti and on opcom it's classed as a corsa c
I have checked with opcom and clutch and 2 brake switches work.
I have obviously got to find a corsa c cruise control stalk and run a wire from stalk to the bcm
Does anyone know what wire and connectors I need and once wire is fitted and activated with opcom will it just be the matter of pushing button on replacement stalk for cruise control to kick in
If anyone has a how to showing how to fit the wire it would be much appreciated
Many thanks in advance
Anyone please
How will I know if I need to add another wire to the engine ecu connector
If its less MJ04
Astra H Caravan Z14XEP 18" OPC Line Rims
https://www.astra-h-forum.de/t/mein-roter-rebell.122867/#post-3363845 My Mods
Then you will good to go.....
Do you happen to know what wire to use and what connectors on each end for wire from cc stalk to bcm
