Page 2 of 2 FirstFirst 1 2
Results 11 to 15 of 15
  1. #11
    Wiring shows its on constant voltage
    There is 2 types
    So for 1st check relay k4 and fuse 20 10amp and fuse 16 5amp by tis its without rec
    Believe you got rec it should be than only fuse 8 15amp
    Whats a hella part numbet?
    Sent from my HTC One M9 using Tapatalk
    • #12
      Member sean-tek's Avatar
      Sep 2016
      Shepton Mallet
      15
      Astra H VXR
      domtorredo - I owe you a beer, fuse 8 had popped I only had a 10 amp spare so popped that in and have a horn again thank you for your assistance id gone right off down the rabbit warren!
      Hella are the company that make the relay I thought was faulty!
    • #13
      It doesnt really matter as long as relay fits and has same pinout and working voltage,
      I would get just relay from scrap yard any size and solder it in wires and than to pcb or look for ones which are fitted in engine bay somwhere in corner with sealed socket cut wires of leaving enaught to work with and solder them to pcb
    • #14
      Yea i know hella one of biggest suppliet to automative industry from components to headlights etc
      Great you got it working and was simply fuse
      10amp should do as you dont use it for long time
    • #15
      Down the rabbit hole you went! Been there many a times..
  1. Advice and help Please - cim module
    By Gadgetman in forum Zafira
    Last Post: 3rd December 2019, 08:37 PM
  2. Astra H UEC version required for auto lights / rain
    By Richard Kerman in forum Astra
    Last Post: 6th July 2019, 11:24 AM
  3. New UEC eeprom chip
    By Miriada 4344 in forum Decoding
    Last Post: 16th June 2019, 07:46 AM
  4. Replies: 7
    Last Post: 22nd November 2013, 07:01 PM
astra h uec positions
astra h uec
vauxhall uec board
uec board astra h
opel uec pinout
astra h cim module indicator repair
opel uec circuit board
https:diagnostics.org.ukshowthread.php6216-UEC-advise-please-got-an-issue-with-the-horn-that-I-dont-believe-is-CIM-related
