You could try this
- switch your headunit off
- press and hold the button arrowed in the picture for two seconds
- the word "system" should then appear on the display
- use the volume up/down wheel to cycle through the menu options. You need to do this slowly, the volume wheel won't work as quickly as the left-hand scroll wheel.
- use the up and down keys next to the volume wheel to change the options/time/date
- When you're finished, press down on the scroll wheel and you'll exit the system menu.
Failing that, Tech2 / opcom can program the date.
