put some hid h7r bulbs in the astra not bad but flickering slightly...is this bulbs or ballast im thinking of changing the bulbs to the shorter ones anyone else done this? astra twintop and hatch
Are they both flickering together or is it just 1 side?
Just noticed this is in the wrong section too.. [MENTION=3]Gairo[/MENTION] [MENTION=5]Smiffy[/MENTION]
Dont worry about the wrong section mate. Im sure one of the mods/ admins will move it. I didnt mean as in here on the forum I meant here as in the mad house and not car chat
Im guessing it could be ballasts. Normally it is ballasts that make it flicker. Well from my experience anyway. Best to see if you can get a spare set of bulbs or ballasts off someone to test it with
Id have said a ballast problem but wierd how they both doing it
Wht years the astra ? Cus the Canbus system makes them flicker to
Sent from my GT-I9505 using Tapatalk
2006 its only a slight flickering they look almost loose as if there rattling with engine on but they do it when engine off...ive put leds in they dont flash.
Happened when I fitted hids to my old mondeo. Bought a relay loom to take the live feed direct from the battery and used the bulb connector as a switch. Worked a treat
Sent from my HTC One using Tapatalk
