Hello all I need to know if my Opel astra cabby should have remote central locking. I have only had it a couple of weeks and I keep thinking that it should but I only have keys to unlock it?
i would of thought so as im sure your supposed to be able to open and close the roof off the fob
Yes it should do as both the cabs ive owned have had remote locking. Maybe the key was damaged at some point and replaced with just a normal key..
Chances are you need a 2 button keyfob and then get it programmed to your car
All g's came with remote locking as far as I know
well my van does
Yeah they definitely all came with remote central locking as standard...
Where can I get a replacement fob from?
Do you have a chip in your key?
If you don't then you'll probably have to change the entire lockset to get a chip that matches
