Results 1 to 9 of 9
    Registered User Lashed's Avatar
    Oct 2012
    45
    Question Speedo SMD conversion. How hard?
    I've currently got the blue led's and want to change them to white.
    Considering that I'm a novice at best when it comes to soldering and electrics (I can wire a plug ), how hard on a scale of 1 to 10 (1 being "can do it blind folded with one arm behind your back") is it to do?
    Am always up for trying something new, just don't want to break my dials!
      VIP Gairo's Avatar
      Aug 2010
      Wombourne, South Staffs
      3,060
      Astra 1.9 16v CDTi SRi XP+ Power Red Estate
      Considering you're a novice then i'm going to say 7+ mate, its fiddly, its a pain in the arse and theres a possibility that you could knacker up the circuit board with excessive heat...
      Oct 2012
      45
      Ah, well the blue does look nice!
      Member M_Blue's Avatar
      Apr 2012
      222
      Pecky has a tutorial on his diagnostics.org.uk site,it shows how to dismantle clocks and which ones to change.
      http://www.diagnostics.org.uk/2010/0...rument-clocks/
      My mate done mine from a similar tutorial but tbh unless you have a steady hand ,some soldering experience and can determine which is the + and - end of the SMD i'd give it a miss.
      Member lh_4827's Avatar
      Jul 2012
      158
      i did the ones on my signum in a few hours, but i started by doing all the door switches and heater controls first to get to grips with it all. i was a total novice at soldering, and grabbed a gas soldering iron and got on with it. used it as a learning curve. if you have a multimeter, it might have a setting to determine the polarity of each SMD, making it easier to match up..
      Member thunderpantz's Avatar
      Staffordshire
      11
      Signum 1.9cdti
      Quote Originally Posted by Luke Harlow View Post
      Or just mark the negative side of the SMD
      Jul 2012
      158
      well yes, thats what i did after testing them all first to figure it out, then matched up the notch on them..
      Staffordshire
      11
      Signum 1.9cdti
      The notch or the green 'tab' is -
    • #9
      VIP Gairo's Avatar
      Aug 2010
      3,060
      Theres a triangular shape cut out of the end of a PLCC2 which helps to distiniguish positive from negative...
  1. what smd's for the IPC
    By gazz292 in forum LED Conversions
    Last Post: 26th February 2018, 01:20 PM
  2. Replies: 3
    Last Post: 3rd July 2013, 12:05 AM
  3. What do i need and How Hard?
    By mull3tt mk5 in forum LED Conversions
    Last Post: 26th March 2012, 10:52 PM
