Pin assignment Pin Color Wire size Option -Function 2 Brown 0.5 - Ground 3 Brown-Gray 0.5 - Heated Seat Switch Signal 4 Black-Brown 0.5 - Tire Inflation Monitor Reset Switch Signal 5 Brown-White 0.5 - Door Lock Lock/Unlock Signal 6 Green-White 0.5 - Hazard Switch Signal 7 Gray-Green 0.5 - Rear Park Assist Disable Signal 8 Yellow-Black 0.5 - Computer Command Ride Auto Switch Signal 9 Black-Yellow 0.5 - Heated Seat Switch Signal 12 Black 0.5 - Ignition Voltage 14 Violet-Brown 0.35/0.5 - Driver Door Lock Status Indicator Signal Ground 15 Black-Violet 0.5 - Hazard Switch Turn Flasher Control 16 Green-Brown 0.5 - Rear Park Assist LED Disable Signal 17 Yellow-Red 0.5 - Computer Command Ride Auto LED 18 Gray-Yellow 0.5 - LED Dimming Signal
