where did you get the connectors for the mirror and rain sensor to build your leads?Hi,
no preinstalled wires at all, my Astra Z14XEP 2006 Estate was naked, upper Image from XE2 shows all you need.
UEC #X2
Pin #38 is 12v+ Ignition
Pin #54 is CanBus Signal to Rainsensor
4PIN Molex:
#1 black +12V Ignition from XE2 #38 > Rainsensor / Mirror #1
#2 Brown Ground > Rainsensor / Mirror #2
#3 Green XE2 Can-Bus Signal from XE2 #54 > Rainsensor #3
#4 Grey Timer Signal > Mirror #3
Retrofitted: AFL, Rear elect.Windows, TPM, DDS, HSA, Recaro Leather, Seat Heat, complete OPC Line all bunch a stuff...
Current Status: fitting in Z20LEH
