Page 1 of 4 1 2 3 4 LastLast
Results 1 to 10 of 34
Thread: Vxr ecu's
Hybrid View
    VIP+ tremo1984's Avatar
    Feb 2014
    stockton on tees
    135
    astra
    Vxr ecu's
    Can some confirm these are vxr ecus please there are out the back of a mates garage and there is also vxr clocks and uec, barrel key ect.
    Thanks jon.
  2. #2
    Yes its vxr ecu
  3. #3
    Maybe you will sell clocks?
  4. #4
    Feb 2014
    stockton on tees
    135
    astra
    Unfortunately not mate I need to identify the ecu that matches the clock and return them to there owner. Which evrr ecu is left will be going on my astra h sri turbo.
  5. #5
    Ok no problem
  6. #6
    Feb 2014
    stockton on tees
    135
    astra
    just been given these, off a mate again he's having a clear out and no use to him so iv claimed them.
    need to some help decoding them as I plan on fitting one and selling other.
    do I have to pull the plastic back off or can I connect to the pins on them and read she chip.
  7. #7
    astra/zafira ones I have had to strip them down and pull the chip... be careful about the ribbon display/bezel, you can release the bezel to avoid strain/lift on the ribbon.. You get the bin file and of course we will help..
  8. #8
    Feb 2014
    stockton on tees
    135
    astra
    so heat it up and pull the back off it read chip, is the ribbon to the plugs mate
  9. #9
    Strip down process, almost in order!
  10. #10
    lemme go find my one
  1. Replies: 2
    Last Post: 12th June 2019, 10:31 AM
  2. vectra c airbag ecu b1000 ecu fault how fix
    By lampinen in forum Vectra
    Last Post: 2nd November 2018, 06:12 PM
  3. New blank 1.3 ECU
    By Miriada 4344 in forum Corsa
    Last Post: 26th October 2018, 05:14 AM
