You need to tell the BCM. You have rear led lights.
MDi will do this.
So i have bought a brand new GTC, it came with no led rear lens, they were a factory option so got the dealer to order and fit them. Now he says it throws up rear bulb brake light failure display on the dash. Pressing the button on the steering wheel stalk turns of the issue warnings. can live with that , but is there a way to eliminate this, a guy told me you can go into the ecu and change the settings in the codes menu. The leds are just on the brake lights and parking light, the brake bulb just throws up the error.
He tried going into the ecu setting but no joy, and used resistors, any answers.
picture is original to led
MDi will do this.
