I have created a piece of software which will tell you the code for parts which have not been divorced prior to removal from the donor car.
If you just need to know the security code of a vehicle in your workshop, remove any of the items covered by the software and read out the code so you can complete your job.
Once the code is known, it can be reset using Tech2 and programmed to a new vehicle.
In order to use the software, an eeprom programmer is required as the contents of the eeprom is loaded into the software.
The software also includes a mileage correction calculator so you can correct mileage of selected vehicles.
More Information Can be found at tech2.guru
