Page 2 of 2 FirstFirst 1 2
Results 11 to 12 of 12
  1. #11
    Member crazibrumi's Avatar
    Dec 2012
    Birmingham
    101
    2005 Vauxhall Astra 1.9 CDTI 150
    this happened again tonight seems to have re appear after a couple of weeks, this time it was at work car park, so dismantled it and clean it out with a compressor and some wipes so hopefully it doesn't do it again for quite some while. Would the code suggest from previous opcom test its pedal. ideally i need to get it on opcom when its actually doing it to check for voltage to rule out the ecu.
  1. ecu power pins on a vauxhall astra 1.4 mk petrol 2006
    By stevenmralph in forum Introductions
    Last Post: 25th October 2019, 08:36 AM
  2. vectra c airbag ecu b1000 ecu fault how fix
    By lampinen in forum Vectra
    Last Post: 2nd November 2018, 06:12 PM
  3. Astra vxr pedal test codes 62102 and 13008
    By Clarkey in forum Astra
    Last Post: 28th October 2014, 03:00 PM
https:www.diagnostics.org.ukshowthread.php5556-HELP-Astra-1-9-Pedal-amp-ECU
112052 error codeerrorcode 112052pedal test code 112052pedal test code 112052 1.9 cdti
