Results 1 to 2 of 2
    Member Lansa's Avatar
    Feb 2018
    Antwerpen
    12
    Astra J 1.7CDTi 96kw, Sport tourer
    Astra H retrofit parking pilot
    Howdy folks,
    on my 2007 Astra H Estate i'd like to retrofit PDC.
    I've bought the following parts so far:
    -PDC module (GM 13228779 )
    -PDC off button for dashboard (GM 13100106 )
    Still need the loom for the sensors and the sensors themselves.
    However i've stumbled upon an issue, with this PDC module (which came off a 2008 twintop),
    it requires a connector which leads to the IPC, apparently it uses the speaker in the IPC.
    My vehicle does not appear to have this extra connector in the boot. And it requires a retrofit.
    Would you folks be able to help me along with this? I need info on that connector, and which cable needs to be pulled to where.
    Thank you kindly!
    (REC has the fuse for PDC)
  1. Astra H Park Pilot retrofit
    By vasilik in forum Astra
    Last Post: 7th April 2021, 07:25 PM
  2. astra h ver parking sensors
    By ash121186 in forum Electrical
    Last Post: 18th February 2017, 06:08 PM
astra h pdc cim
astra h pdc retrofit
https:www.diagnostics.org.ukshowthread.php7664-Astra-H-retrofit-parking-pilot
https:diagnostics.org.ukshowthread.php7664-Astra-H-retrofit-parking-pilot
