I need the part number for the park pilot sensor brackets for an Astra h estate/van (mines a van) the ones which glue to the bumper. There’s 5 different types listed on 7zap the ones I’ve found are part no 93188389
https://vauxhall.7zap.com/en/car/a04/p/11/42-0/
The ones I’ve found are part 25x on the diagram !.
26x 93188390 12 39 991 bracket, sensor, primed (kit) estate,van l35,l70 1
one will fit and the other will not lol.
Where does pin 7 and 16 connect too ?, as I don’t have the wires in those 2 locations !.Could you check if you have all wiring present at switch module pin 16 and pin 7 if they are present than its down to coding, but if you want we can do some more complex checks, check on ipc connector between pin 31 and ground resistance switch pressed should be reading from 95 to 113 ohm and switch not pressed 1.7 to 1.9 kohm
