chip is reuseable... only swap chips from one ipc to another if IDENT / part number matches..
post up bin file or use peckys decoder to correct mileage and find out pincode
I bought a vectra c opc -07 instrument panel.
I do not have a security code to it.
and the odometer reading should be replaced.
succeed on the same chip?
I have Pecky decoder.
where the chip is located in the Vectra OPC in the instrument cluster?
for mileage its in engine ecu and also IPC.. under display LCD its 93c66
opc ipc 225847km.rar
i need 143342km
i find security code 8137
Now the job ok in every way.
thanks
Hi, i can not download the eeprom dump rar file, can you send me pls?
