Hi All,
I need to convert a speed signal to work with the Zafira B clocks (Canbus) that I am using in a kit car. I have another gearbox I am using and want to use a 6 pulse Astra GTE transducer to give the ABS its speed signal so I can use a different hub and gearbox pairing.
Does anyone know the pulse output of the standard ABS sensors or if there is a way to covert the signal to work with the ABS system?
Cheers,
