Hi Guys
Pretty new here. I have a question some one might be able to help me with.
I need the pinouts for a Astra f/g idle speed control valve. Its the 4 pin one.
The reason is. I am doing a engine conversion on my Opel Astra Estate 1.6.
i have replaced the motor of the car which was a 1.6 8v motor with a 1.6 16v Echo tech motor out of a Zafira.
I am using a Spitronics Orion2 Advanced ECU. I have the car starting but i have not as yet connected the Idle control valve.
I have two options .. connect up the Valve and get the idling to work properly with the ECU .. which may need a stepper motor control.. or if i am lucky connect it with out the stepper motor control.
Other alternative is blank off the idle control valve port .. not Shure how i would do that.
Oh yes the Throttle body is the one that does not use the Electronic throttle control.
I hope some one can help me.
Tiaan
