Results 1 to 10 of 13
    VIP Nitrousvaux's Avatar
    Jul 2021
    Birmingham
    24
    Nova (with Zafira B Z20LER to be fitted)
    AC / Airbag / Tyre pressure monitor delete on Zafira B
    I am going to use the zafira canbus loom in a kit car and I need to omit the AC / tyre pressure monitoring and the airbags on the network to avoid the dash lights coming on.
    With the air bags, so far from my research, I need to find the right resistors for the system (any ideas) but the other two I am not sure what is the best way to isolate them.
    I have EEPROM reader and OPCOM and a little handy with the electronics.
    Thanks,
      1,335
      tpms, you can disable the warning light from the instrument cluster itself, then take it off the low speed can
      Jul 2021
      Birmingham
      24
      Quote Originally Posted by soulman View Post
      I may have to get you to explain a little bit more, when I am further ahead with the vehicle. I had the CD30 pass code but thats not the engine pass, so now trying to get the rear electrical centre out of the vehicle to read that eeprom then may be able to get into the system a bit more. Or can I do that above without the pass code?
      Cheers,
      1,335
      need the code unfortunately
      Jul 2021
      Birmingham
      24
      I am just a little nervous as after getting the eprom dump for the CD30, it no longer works!
      Jul 2021
      Birmingham
      24
      Hi Soulman, I managed to read the rear electrical centre eeprom and now have the car pass. Tested it by clearing the ecu and nearly buggering things up!.
      Wondered if you could point me in the direction of how to do the above and remove it from the CAN? I was wondering, what else could be removed from the CAN before the engine ECU stops working?
      Thanks,
      1,335
      just go through the modules, look at Low Speed CAN settings, anywhere you see it set it to 'Not Present'
      Jul 2021
      Birmingham
      24
      Thanks Soulman will do. I am guessing this wont work with the Airbags? CIM etc? ABS I know I need for the speed signals, unless I can get a transducer to replicate the speed signal.
      Jul 2021
      Birmingham
      24
      Tried that, still getting the symbol on the dash. Same for the air bags, disabled those too. I may, as dont need them, just de solder them on the clocks and live with it.
      1,335
      have you turned off tpms in the variant config on the cluster?
      airbag lights issues you have to fix the problem, you cant turn them off
  1. Replies: 3
    Last Post: 9th January 2016, 04:54 PM
  2. Tyre Pressure
    By holdensri100 in forum Corsa
    Last Post: 24th March 2014, 06:33 PM
  3. Vectra tyre pressure monitoring system
    By sarah1331 in forum Vectra
    Last Post: 14th March 2014, 02:33 PM
