Results 1 to 4 of 4
    Member AresUltio's Avatar
    Apr 2019
    İle
    17
    Astra Mk5 1.6 115 hp
    Question Astra H speedometer error (ıpc) help me
    Good day to everyone.I have a 2012 astra h 1.6 vehicle.I bought an opc speedometer.kilometers high. I went to eepromcu to reduce the mileage of my own vehicle.The eeprom maker deleted some of the information in the eeprom while changing the mileage. the rpm on the speedometer and the needle on the speed section go down directly to the bottom.While reading the eeprom, it could not fully read the device, I guess, most of them see the data as FF.I have to throw its own software on the speedometer to figure it out.How do I reinstall the original software installed on the speedometer?opc speedometer version: 0.502 49/04
      Member Arbe_GTC's Avatar
      Dec 2010
      Madrid, Spain
      13
      Astra H GTC 1.9CDTI & Astra K 1.6T
      You need a eeprom dump from IPC number 13216707 QF (OPC instrument Cluster) to restore your eeprom.
      to reset the kilometers to 0 change the first 16 positions to 0
      00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
      and
      Position 17: 01
      Position 19: 00
      Example:
      First image from this post: https://www.diagnostics.org.uk/showt...ileage-ASTRA-H
      After restore the dump, you should be able to program your kilometers with opcom without problems.
      Carpass is in positions 234 to 237
      The best way to restore the eeprom is to desolder, program and solder the eeprom on the instrument panel.
      If you no desolder the eeprom, you so many troubles to read and write the eeprom.
      VIP+ RoyReijn's Avatar
      Sep 2021
      North-Holland
      5
      Astra H MK5
      Do you have an OPC cluster eeprom dump? I’m desperate to find one…
      Dec 2010
      Madrid, Spain
      13
      No. You can use a gasoline (or find a newer opc instrument cluster(more difficult and expensive)) instrument from 2007-8 (SW7.655, change the leds to white and enable the scan OPC in the eeprom) Be carefuly, some instruments dont work sport button, ParkPilot, ids... Sould be a Sport instrument from a car whit any optional extra, like Parkpilot.
      Its a possible solution.
  1. Replies: 1
    Last Post: 28th January 2018, 11:28 PM
  2. Astra j speedo error
    By Sony96 in forum Astra
    Last Post: 8th November 2016, 10:04 PM
  3. Help with Speedometer
    By Alexfitton in forum Questions and Info
    Last Post: 11th May 2016, 09:11 PM
  4. Astra H VXR CD70 CD ERROR, help please
    By Clarkey-kris in forum Astra
    Last Post: 25th August 2014, 01:38 PM
