had some problems with the car losing power fault codes pointed to cam shaft senors and cam shaft solenoid
changed them now after you have left the car over night it just hard to start but turn the key back then it just starts
code coming up now is u2100 can bus malfunction? car drives fine just when starting is the problem but it dosent do
it all the time
