Results 1 to 2 of 2
    Member SportiveSE's Avatar
    Feb 2018
    Lincoln ish
    27
    Astravan
    Park pilot wiring
    Hi all
    I’m retro fitting park pilot in my van. But I could use a wiring diagram if anyone has one !.
    There’s 2 plugs on the park pilot module I know that one of these is the canbus (only 1 wire in it green) and it goes to pin 29 on the bottom plug on the rec.
    The other plug has 8 wires !
    Solid black - thinking this is power to the module
    Solid brown - thinking earth for the module
    Black with white stripe - thinking power to the sensors
    Brown with white stripe - thinking earth to the sensors
    Then I have
    Solid yellow
    Yellow with white stripe
    Yellow with purple stripe
    Yellow with red stripe
    Thinking these are the sensing wires but don’t know which is which sensor !.
    Also need to know which pin is which on the sensors if anyone knows !.
    Thanks in advance
  1. Park pilot wiring?
    By bruce1234 in forum Zafira
    Last Post: 19th September 2015, 08:00 AM
