Can someone tell me how I should wire the entire ahl unit and if I have to change any pin location,
Astra h 2 door.
Thanks a lot
Astra h 2 door.
Thanks a lot
Pin 2 --HSCAN-H
Pin 3 --HSCAN-L
Pin 5 --UEC XE2 pin12
Pin 7 --Car lever sensor rear pin 3
Pin 10 -- Car lever sensor rear pin 2
Pin 11 -- Car lever sensor rear pin 1
Pin 23 -- UEC XE2 pin 39 from fuse FE33
Pin 24 -- GNG
Is this how it originally comes?
which would be the GNG, where is it located
Thanks a lot : pulgares: .
This is how it shows in wiring diagram.
Pin 24 is Ground sorry typo...located below UEC.
You can connect pin 24 anywhere where it is in good ground.
It is originally below UEC.
There is a bolt for it...
There might be other brown wires in it.
I already understood, perfect :aplausos:
I need to know
have the wiring for the headlight washer pump and what fuses it has and what options do I have to program to make Ahl and headlight washer work
Thank you so much for help me .
Headlight washer has fuse FE9 and relay K7_X125 , both in UEC.
I think washer need no programs at all.
Take a look all modules and these configurations.
If you find anything about AFL , make it present.
Have you read this?
https://tech2.guru/astra-h-retrofit-afl-headlights/
