Results 1 to 9 of 9
    Member Typeone's Avatar
    Dec 2020
    Portugal
    5
    Astra H
    Demisting buttons not working after LED change
    Hello, I changed the leds to white. Since then, the buttons for demisting the rear and front windows do not work, the two on the right of the ECC with AUTO ...
    As it has been like this for a long time, I am not sure if I changed something in the programming so I need help to make sure it is all set nicely.
    In some modules it discriminates if the "ECC" is present?, in others it talks about "ECC/SAC" present or not, and in others it only SAC.
    What options should I choose present and not present for each of these questions?
    I have the Module with Auto (ECC I think) 7 speed ... and GID of 2 lines.
    Thanks.
      VIP+ kadett90's Avatar
      May 2014
      Finland
      230
      Opel Astra H
      If you have Astra H and we are talking about bus configurations the values are:
      SAC not present
      ECC present
      Dec 2020
      Portugal
      5
      Astra H
      Thanks, it might seem obvious but some module names are confusing.
      That didn't fix it, will try some different SMD's...
      Another thing I noticed, I have Electrohydraulic Power Steering, and on that module programming options its set like:
      Electrohydraulic Power Steering: Not Present
      ABS/TC/ESP: Not present
      Should I change it or let it be?
      My car has ABS only, but every other modules has the "ABS/TC/ESP" as present...
      Dec 2020
      Portugal
      5
      Astra H
      Yet another one that I would like to compare.
      If my battery voltage is reading 12.5v on display, if I check with op-com the IPC module has a tension of just 11.7V
      That has got to be wrong right?
      May 2014
      Finland
      230
      Opel Astra H
      Quote Originally Posted by Typeone View Post
      They should be in present.
      May 2014
      Finland
      230
      Opel Astra H
      2
      If you mean IPC system voltage it shows about 11.2-11.5V...About 1V below battery voltage...Its okay.
      Dec 2020
      Portugal
      5
      Astra H
      Thanks a lot for your feedback. Couldnt find that even in autodata...
      I thought the 11.7v was a problem because I always have erros relating to "no communication" in CIM Module.
      Been cleaning fuse box contacts and ecu it seems to change but. Gets back to it. Ever heard of something like that? No error lights... 2004 Astra H
      May 2014
      Finland
      230
      Opel Astra H
      When you look with Op-com the data list in ECC and you push the rear window heater button when car is idling does the rear window heater status change?
      Dec 2020
      Portugal
      5
      Astra H
      It doenst register the button being pressed.
      If I activate the rear demister via opcom it works.
      Its not that I actually use any of those functions but...
      The auto button and recirculation work.
      All leds work.
      It has to be the leds that affected the circuito somehow.
      Thanks anyway.
  1. cd70 navi buttons does not work
    By drakaz in forum Zafira
    Last Post: 20th June 2013, 09:02 AM
  2. LED Canbus bulb not working in estate boot
    By MarkG in forum Electrical
    Last Post: 8th October 2012, 11:38 AM
