Results 1 to 10 of 10
    Member Arbe_GTC's Avatar
    Dec 2010
    Madrid, Spain
    23
    Astra H GTC 1.9CDTI & Astra K 1.6T
    Question IPC in miles after program mileage [ASTRA H]
    Hi, i programmed a XK IPC (The IPC is in kilometers) but the IPC now IPC count the kilometers in miles instead of kilometers.
    Por example, the partial of IPC shows 1.4 miles and the CID Display shows 2.3 KMs.
    Are any way to change this in the IPC? i have tech2 and mdi2 (Tech2WIN)
    Before programming the IPC the eeprom content is this (attached image)
ID:	2482 (all 0 to program whit tech2 or mdi2)
    Any ideas?
    Thanks!
  1. Vectra c opc -07 ipc code+mileage
    By lampinen in forum Vectra
    Last Post: 3rd January 2024, 07:15 AM
  2. IPC mileage
    By vpug in forum Astra
    Last Post: 20th May 2016, 09:59 AM
  3. IPC display (not the dial card) KM vs Miles
    By soulman in forum Vectra
    Last Post: 4th August 2015, 01:54 PM
  4. Replies: 1
    Last Post: 17th July 2013, 08:32 PM
https:www.diagnostics.org.ukshowthread.php9669-IPC-in-miles-after-program-mileage-ASTRA-H
