Results 1 to 2 of 2
    Member Shavo's Avatar
    Jun 2020
    Poland
    8
    Astra H 1.6
    Can't calibrate window's motor in the upward direction
    Hi ! It's me... again :/
    I recently bought used original window's motor for replacement. I calibrated it for automatic window closing\opening after i stop push button. Everything was working fine. Motor was calibrated alright and i could open\close it by remote. But then i noticed that seller sent me incomplete motor's mechanism so i must return it and i bought another. But after second motor arrived and i plugged it in something awkard happened. I couldn't calibrate it. I mean when i close window and after i stop pushing button then window close independently and it's fine. But when i do the same for opening then motor stop right after the moment i stop pushing button. I thought that the motor is broken so the seller send me second one. It was the same. So i was like "what the f... ? Second motor broken same way ?". Anyway i bought third motor from another seller and again without luck...
    Could someone tell me how it is work ? I mean is motor close\open window by itself ? Or REC do this ? I bought window's mechanism using official part number 13101478 (got it from the vin). And one more thing - after all these things happened i connected my previous motor (which is non original) and i calibrated it without problems. Can you please help me or maybe give a little tip where should i search source of my problem ?
  1. chainged starter motor wont start
    By big ken in forum Astra
    Last Post: 10th November 2015, 06:59 AM
  2. Zafira Blower Motor
    By Anderton in forum Zafira
    Last Post: 22nd December 2012, 09:34 PM
  3. the motor
    By kj76 in forum Members Cars
    Last Post: 9th December 2012, 12:36 AM
  4. sisters chaps new motor
    By ANT-VXR in forum Astra
    Last Post: 8th April 2012, 11:15 AM
