Page 1 of 2 1 2 LastLast
Results 1 to 10 of 13
    Member Shavo's Avatar
    Jun 2020
    Poland
    8
    Astra H 1.6
    One window doesn't open by remote
    Hi there. I've got problem with my Astra H 1.6 2006 GTC. One window doesn't open by remote. Passenger's window works just fine - open and close by pressing open/lock buttons on remote. Beside of this malfunction, driver's window works great. I can open\close it by door switch and even close it using remote. I've already checked wiring loom and door's connector - no broken wiring. Can someone provide me guide what to check next ? Or connector pinouts description so i could check if there is correct voltage at all of them ?
      Member jpbroad1970's Avatar
      Aug 2015
      northants
      218
      Astra 1.6 VVT Elite 2011
      Does the 1 touch down work on passenger side?
      Sent from my Pixel 3 using Tapatalk
      Aug 2015
      northants
      218
      I mean drivers side
      Jun 2020
      Poland
      8
      Astra H 1.6
      You mean that if i push and release button then window would go down independently ? Yes it would. I checked today errors in REC module and got "B3803-00 - faulty operation of comfort closing windows circuit". But i can't reproduce that error after erase...
      VIP+ kadett90's Avatar
      May 2014
      Finland
      230
      Opel Astra H
      Door connector pin 9.
      There is brown/Black wire.
      It is comfort closing signal for window.
      Jun 2020
      Poland
      8
      Astra H 1.6
      Thank you for your reply. I just found that pin at the wiring diagram and checked it. There is continuity between door plug and REC module. And between door plug and the fuses too. I will check wiring inside door next...
      Jun 2020
      Poland
      8
      Astra H 1.6
      I checked wiring inside the door and it's ok. So there are 2 things left: REC and window motor. But its weird... What do you think ?
      May 2014
      Finland
      230
      Opel Astra H
      Do you get any voltage to this pin when you push lock button continually ?
    • #9
      Jun 2020
      Poland
      8
      Astra H 1.6
      So here is the deal... At the brown/black wire there is constant +12V. When i try to open windows by remote then voltage drops to ~5,8 V. When i close both windows by remote then voltage drops to ~0 V. Both windows wirings behaves the same so i think wires are ok... I think that window's motor is guilty. But im not sure because i still don't know how this thing works. How could motor rotate both ways if there is only 1 powering wire (for comfort closing\opening) and only thing that changes is voltage, not polarity of current :/ ?
    • #10
      May 2014
      Finland
      230
      Opel Astra H
      Quote Originally Posted by Shavo View Post
      If you remove connector from driver's window motor does the voltages stay the same when you commands windows with remote?
      Or have you measure that without this connector loose?
  1. Corsa D doesn't start after BCM changing.
    By Lightning5686 in forum Corsa
    Last Post: 4th April 2021, 04:11 PM
  2. CD30 AUX fitted now ECC doesn't work
    By Kawikris in forum Infotainment - ICE - In Car Entertainment
    Last Post: 13th August 2017, 10:11 PM
  3. Remote control keys
    By Pires99 in forum Astra
    Last Post: 18th June 2012, 12:31 AM
https:www.diagnostics.org.ukshowthread.php9593-One-window-doesn-t-open-by-remote
