Check fuses FE23 and FE31 in UEC.
Hi all been a while. Did a service on my astra h vxr including gearbox oil. Took battery out done the job put battery back in and now afl are not working properly. Got fault code u1113. Any ideas. Cheers all.
I have all fuses are fine.
Yes. Think the control module has blown on that light.
Ignition OFF
Remove electrical component from socket:
A3_E119L Power Light Module, Left
Ignition ON
Trouble Code Update
Is the diagnostic trouble code U1113 with status PRESENT stored
I will try that. Also going to swap them around see if it changes to the other side. They dont move on start up and the other side goes out.
