Results 1 to 4 of 4
    Member gokhanyakin's Avatar
    Mar 2020
    TR
    2
    Corsa D 1.2
    Corsa D 1.2. P0130 Fault Code Problem
    Hi Guys,
    My Corsa Z12XEP engine, my car dashboard engine lights on,
    Wurt odb scan ecu found fault codes P0130, I changed lamdba sensor 1, and clear the fault codes obd scanner, i drive to 10-20 kilometer and engine lights on, i connnect the wurth obd scanner, scan fault codes, obd scanner found the P0130 faut codes, lambda sensor wiring cables checked I cound't find any problem, can this fault come out of another place and where else should I check?
    Thanks for your help with this malfunction.
    Best Regrads.
    https://m.imgur.com/a/fzyedV4
    SM-G970F cihazımdan Tapatalk kullanılarak gönderildi
  1. Corsa D BCM fault?
    By GazzaC in forum Corsa
    Last Post: 9th September 2017, 10:08 AM
  2. Corsa d 1.2 p2188 fault code
    By Slacky in forum Corsa
    Last Post: 27th April 2015, 09:59 PM
  3. Corsa C Speedo Fault
    By Adz in forum Corsa
    Last Post: 8th October 2014, 08:52 PM
  4. zafira a 1.8 2001, p0130 and p0443,
    By carpcrew in forum Zafira
    Last Post: 14th March 2014, 01:42 PM
