hello everyone
can somebody help me explain the problem with programming the new ECU from Corda E 2017,
I change before BCM, ECM for insignia, meriva B, astra j and don't have that problem.
I have the code for the car and code for the second ECM, part number same like original, and during SPS where I need to reset the code first, I go to "prepare control module for removal", but did not ask for security code at all, but the process was successful (pictures), and during immo learn also does not ask for the code and after checking it shows "FE05 security code input incorrect" (pictures) so look like don't resetting old code, earlier models there was no problem with resetting the code in new car, some new security proces that need to reset in original car first?
thanks
Name:	2020-03-14 12.33.30.jpg
ID:	2421Click image for larger version.
Name:	2020-03-14 12.37.52.jpg
ID:	2422Click image for larger version.
Name:	2020-03-14 12.40.18.jpg
ID:	2423Click image for larger version.
Name:	2020-03-14 12.40.44.jpg
ID:	2424Click image for larger version.
Name:	2020-03-14 12.40.52.jpg
ID:	2425Click image for larger version.
Name:	2020-03-14 12.41.10.jpg
ID:	2426Click image for larger version.
Name:	2020-03-14 12.49.06.jpg
ID:	2427Click image for larger version.
Name:	2020-03-14 12.52.11.jpg
