Page 2 of 2 FirstFirst 1 2
Results 11 to 12 of 12
  1. #11
    Quote Originally Posted by gary k View Post
    silly question but is this the underneath view of where the fuses and relays are in the box adjacent to the battery?!
    if so, how does the board holding the fuses and relays come out, I can see the three torx bolts
    Fully undo the 3 torx bolts and the 10mm nut under the top cover. You then just pull it up to remove.
    The torx are captive so do them until they spin.
  1. Cruise control wire connectors
    By haribo123 in forum Corsa
    Last Post: 20th February 2017, 06:04 PM
  2. Coolant bootle wiring loom for check control
    By johnnevett in forum Astra
    Last Post: 9th November 2012, 07:02 PM
  3. Sussing out the check control wiring
    By cross-keys in forum Zafira
    Last Post: 5th March 2012, 09:51 PM
  4. 2204 - Display, Check Control - Wrong indication "Check Coolant Level"
    By pecky in forum Zafira B Technical Service Bulletins
    Last Post: 2nd July 2011, 12:32 PM
astra h uec
uec astra h
uec zafira
uec opel astra h
connector uec astraastra uecplaats uec astra huec astrazafira b uecuec astra h disassemblinguec opelzafira uecopel astra h recopel uecuec zafira bopel astra uechttp:www.diagnostics.org.ukastraREC.jpgvauxhall wiring connectorscoolant sensor connector zafirazafira check controldoes the astra mk4 have a uecuec vauxhallpart number for astra connector to coolant sensorzafira coolant connectorenabling check control zafira b
