I have tried with Tech 2 and the result was that the display only have available code Index 001 and 002. My question is: Is it possible to reflash the display in order to have all the index codes available?
Assuming you are still talking the CID, then yes you can usually upgrade the firmware to give the other code indexes. It certainly works on the CIDs with the KS sticker on the back.
Hi I just put in a paired GID display with the cdmp30. Astra 1.6 design 55 plate. The cdmp30 is from a 2007 Astra 1.9. Everything works except the range. The code index atm is 009. What should it be for the range to work?
If remember than 007
Hi Pecky , I have recently activated the range etc on my Astra (2007 with BID) but I'm reading through u forum and it says with or without BC I don't know what BC is . The range works but it's wrong it says I have 200 odd miles when I have 1/4 of a tank can u please help
Chris
BC is board computer
You must use correct code index for your car to get correct readings
So you should use code index 010
