Does the Cruise control light illuminate if you commands it with tester?
Hi,i just retrofitted the cruise control on my 2003 zafira and it works correct. I also placed the led light with the proper resistor.Do i need anything else such as a wire from ecu to instrument panel ,so it will indicates its function???Thanks in advance!
But it won't work with cruise on.
Yes it is not working when cc is enable
What about instrument conficurations.
Is there cruise enable?
This thread is about identical question, so I don't start new one just write here.
As topic creator - also I have recently retrofitted Cruise Control into my Zafira A 2004 Z16XE .
It works great, but there is no any CC light appearing on the dash board.
I found this thread, so now I wonder what LED (bulb) and resistor to be fitted where to get the CC light on dashboard ?
Another thing is that I don't have Tech2 device as it's incredibly expensive as for self service only.
In Opcom (which I've used) there is just one option in "Instruments" menu and it's not related to lamp indicators (as I remember it's something about odometer)
So in short words - my question is:
What do I need to do to get CC indicator on dash board working ?
Have you checked the instrument configurations to ensure that the Cruise Control is enabled, and do you know what LED and resistor are required to make the Cruise Control light work on the dashboard?
