Results 1 to 4 of 4
    VIP astra1.7's Avatar
    Sep 2012
    Fordham, Newmarket
    90
    Astra vxr Nurburgring Edition 267
    Reading different m35080 chips
    Hi guys
    I've finally got round to buying a cheap upa USB programmer and Richard's decoder software. I've been having a play tonight with a couple of IPC's. The first one read fine after a few attempts which was a bog standard 1.8 astra ipc. The second one I'm having trouble with, which is a keyless vxr ipc. I can get some bits of coding, but not enough to pull the security codes. Is the chip damaged or do you think I could salvage it if I desoldered it? Or any other ideas?
  1. M35080 - EEPROM Programer
    By Lightning5686 in forum Decoding
    Last Post: 20th November 2017, 08:30 AM
  2. IPC - M35080 - Astra H - ident RX
    By rollyone in forum Dump Archive
    Last Post: 6th February 2017, 09:39 PM
  3. IPC - M35080 - Astra H - ident QB
    Last Post: 6th February 2017, 07:59 PM
