Sorry, submitted before I finished and can't find edit button!
So the lower part with the gaps for ventilation I removed no problem using the 90o twist. It's the part above the red line thats the problem.
Cheers,
Andy
Hi folks,
Been searching around for a while and cannot find it, before I delve into the world of Haynes and/or spec manuals anyone got an easy HOWTO removing the lower plastic trim below the steering wheel to allow me access to the top of the pedals? Been trying to find the torx screws behind obviously holding it and cannot locate!
Photo to help:
Cheers
Cheers,
Andy
There are 4 screws holding it.
Two are behind the Headlight switch, and two behind steering column
Sorry, I am talking about Astra
Ah, no problem! Was about to say, I had the small plastic facia off below the light switch and there was nothing there as had seen previous posts/info on that.
Still no luck finding them, gently pulling on it, feels like there is something holding it in rather than push/clips.
