Hi
Does anyone know if it's possible to reprogram the cruise control ratios on a mk4 astra?
I have change the gearbox to the six speed and all was working as normal. I have now replaced the sixth gear with a different ratio to reduce the revs but the downside of doing this is that the cruise control now only works in the first five gears :-( so I'm assuming there is a table in the ecu with a speed to rev limit and the new gearing is outside this
Dave
Sent from my E6633 using Tapatalk
