hi trying to sort out the daughters car getting two ecn codes when pressing the brake and accelerator pedels ECN59761 and ECN1462
Any help on what they are and what to do please
Cheers
Dave
Cheers
Dave
Have you tried the dtc checker on the forum itself? Its on one of the tabs above..
P0597 Coolant Thermostat Valve Stuck
-System/component mechanical fault
P0014 Exhaust Camshaft Phasing Mechanics Range/Performance
- The control unit recognises a wrong position of the camshaft
Check your timing first
Sent from my F3111 using Tapatalk
If yours is 1.6 twinport remove engine mount, cover off and check if marks are aligned turn it couple times, there is bottom one aswell on crank but if top ones are out no point to check bottom.
