Hello everybody,
i have a 2007 Vectra with a CID fitted. Unfortunately the CID does not have the BC tab activated and i am not able to activate it. When connecting to the CID with my trusty "plopcom" it takes a very long time to retrieve the information about model number, software date etc. The entries appear at a rate of about 4 to 5 seconds per line, so something must inhibit the display from communicating correctly. Therefore variant coding is not prossible, i get different errors when reading the current variant config, most of the times it says "not all DID readed correctly". Also, the programmed VIN can not be read. What does in fact work is set the time in the CID and changing of code index.
Has anybody else experienced such a behaviour?
Of course i would really like to activate the BC tab, so i thought about flashing a different image to the EEPROM. Would that work? I read online that the EEPROM content would be hardcoded to a specific display and would brick other units that the image would be flashed to?
Thanks in advance
