hoping you can help me Iv had a look at guide on here and I have rec and terminals for relay and fuses but don't have under seat and switch wiring . If I understand right there are three pins on the chair connector block for the heated seat using pins 7,8 and 9
7=switch signal wire
8=12v ign feed
9=ground/ earth
Firstly I need to know if the grey handled connector on the REC that is missing the two pins , are these two wires the 12v ign feed for each chair or where do they terminate also where does pin 9 need earthing to chassis or back through switch ?
Secondly if signal wires are missing from switch to x1 connector can they be wired directly to pin 7 or do they go to x1 connector then to pin 7 or is there some missing in between . I could probably manage with a decent wire diagram but can't find any online or names/ codes of the different types of pins I would need to order to install the seats correctly. I have scan tool to enable on can bus also. Please any help is appreciated or if you sell a kit with The stuff I need I'll happily buy it any advice would be brilliant as I want to do it right but need to know where wires terminate thankyou
