Hello guys
Can someone help my to get security code from REC ith from ASTRA H 25040 EEPROM
Thank You
REC_ASTRA_H.bin
Hello guys
Thank You
REC_ASTRA_H.bin
It works.
Thank you for code.
Can you help me with pin from BCM Corsa C EEPROM 93C66
I need to change ECU and i need PIN from that dump.
CORSA_C_BCM.bin
unable to read the format.. is that a hex file?
As soulman said, it looks corrupt
Gav
not corrupted but looks like hex file
Did u come rightIt works.
Thank you for code.
CORSA_C_BCM.bin
Sent from my WAS-LX1 using Tapatalk
